grigor1s 1.558 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 13 , 2014 (τροποποιήθηκε) Καλά ξεκίνησε η Formula-E τελευταίως γύρος τελευταία στροφή. :P Τροποποιήθηκε Σεπτέμβριος 13 , 2014 από τον grigor1s 2 Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
Παναγιώτης Κ. 10.057 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 16 , 2014 Από τον επόμενο αγώνα μπαίνει φρένο στην ανεξέλεγκτη επικοινωνία οδηγού - ομάδας. Σύμφωνα λοιπόν με την νέα οδηγία, επιτρέπονται και απαγορεύονται τα παρακάτω: Message types allowed - Acknowledgement that a driver message has been heard. - Lap or sector time detail. - Lap time detail of a competitor. - Gaps to a competitor during a practice session or race. - "Push hard", "push now", "you will be racing xx" or similar. - Helping with warning of traffic during a practice session or race. - Giving the gaps between cars in qualifying so as to better position the car for a clear lap. - Puncture warning. - Tyre choice at the next pit stop. - Number of laps a competitor has done on a set of tyres during a race. - Tyre specification of a competitor. - Indication of a potential problem with a competitor's car during a race. - Information concerning a competitors likely race strategy. - Yellow flags, blue flags, Safety Car deployment or other cautions. Message types not allowed - Sector time detail of a competitor and where a competitor is faster or slower. - Adjustment of power unit settings. - Adjustment of power unit setting to de-rate the systems. - Adjustment of gearbox settings. - Learning of gears of the gearbox (will only be enforced from the Japanese Grand Prix onwards). - Balancing the SOC [state-of-charge of batteries] or adjusting for performance. - Information on fuel flow settings (except if requested to do so by race control). - Information on level of fuel saving needed. - Information on tyre pressures or temperatures (will only be enforced from the Japanese Grand Prix onwards). - Information on differential settings. - Start maps related to clutch position, for race start and pit stops. - Information on clutch maps or settings, e.g. bite point. - Burn-outs prior to race starts. - Information on brake balance or BBW (brake-by-wire) settings. - Warning on brake wear or temperatures (will only be enforced from the Japanese Grand Prix onwards). - Selection of driver default settings (other than in the case of a clearly identified problem with the car). - Answering a direct question from a driver, e.g. "Am I using the right torque map"? - Any message that appears to be coded. Ένα ακόμη νέο είναι η επιστροφή του Πέτρου Προδρόμου στην ΜακΛάρεν. Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
grigor1s 1.558 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 18 , 2014 :thumbsdown: Johnnie Walker becomes the Official Whisky Of Formula 1 1 Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
Gen.Markus 6.229 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 18 , 2014 μη το σκέφτεσαι,όπου φυσάει το χρήμα πάει ο γέροντας. Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
ksino1100 13.310 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 18 , 2014 Και από κόρες, μια χαρά τα πάει!!!! Κλικ μι 1 Κλικ μι 2 Πεθερούληηηηηη μου :lol: Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
Gen.Markus 6.229 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 18 , 2014 Γεια σου Ksino μπατζανάκη!! 1 Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
Schumi 8.191 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 18 , 2014 Παίδες κρατήστε εσείς τις γκόμενες και δώστε μου εμένα τα λεφτά τους και είμαστε κομπλέ. Χαχαχαχαχ :P 1 Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
grigor1s 1.558 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 19 , 2014 (τροποποιήθηκε) FIA revises radio ban to driver performance only Messages not permitted (by radio or pit board) - Driving lines on the circuit. - Contact with kerbs. - Car set up parameters for specific corners. - Comparative or absolute sector time detail of another driver. - Speeds in corners compared to another driver. - Gear selection compared with another driver. - Gear selection in general. - Braking points. - Rate of braking compared to another driver. - Rate of braking or application of brakes in general. - Car stability under braking. - Throttle application compared to another driver. - Throttle application in general. - Use of DRS compared with another driver. - Use of any overtake button. - Driving technique in general. Τροποποιήθηκε Σεπτέμβριος 19 , 2014 από τον grigor1s 1 Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
grigor1s 1.558 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 19 , 2014 Πάλι "φωτιά" βάζει η Ferarri να δούμε τι άλλο θα αρπάξει το σαββατοκύριακο :P Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
Schumi 8.191 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 20 , 2014 Κρίμα για τον Κιμι. Και έδειξε ότι έχει την ταχύτητα. Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
Gen.Markus 6.229 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 20 , 2014 2 Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
grigor1s 1.558 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 20 , 2014 Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
Gen.Markus 6.229 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 21 , 2014 (τροποποιήθηκε) αποτελέσματα αγώνα Τροποποιήθηκε Σεπτέμβριος 21 , 2014 από τον Gen.Markus Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
Wolf1138 2.924 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 21 , 2014 Άτυχος ο Rosberg με το πρόβλημα στο τιμόνι. Από την άλλη με τη νίκη του Χάμιλτον το πρωτάθλημα ξαναπήρε φωτιά. Μάλλον στη Σουζούκα ανακοινώνει η McLaren - Honda (από του χρόνου) τον Alonso για του χρόνου. Φημολογείται ότι θα εξαγοράσει έναντι 30 εκατομμυρίων το συμβόλαιο του από τη FIAT. Αχώνευτος είναι ο Γκαστόνε αλλά αυτή τη στιγμή ο κορυφαίος οδηγός. Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
Schumi 8.191 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 22 , 2014 Σύμφωνα με τη Gazzetta ο Alonso έχει εκδηλώσει την επιθυμία του να φύγει από την Ferrari από του χρόνου. Καλύτερο timing για να το σηκώσει η Ferrari του χρόνου δεν θα υπάρχει. Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
Gen.Markus 6.229 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 22 , 2014 Αχώνευτος ο Ισπανός,αλλά για μένα το καλύτερο τιμόνι αυτή την στιγμή. Δε νομίζω να υπάρχει άλλος που να παίρνει τα μέγιστα απο κάθε μονοθέσιο που οδηγεί. Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
grigor1s 1.558 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 22 , 2014 Η McLaren δεν νομίζω να τον αγοράσει η Honda μπορεί αφού μόλις διάβασα ότι η McLaren έχασε και τον μεγαλύτερο χορηγό της ~140 εκατομμύρια δηλαδή :P Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
Gen.Markus 6.229 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 22 , 2014 Μα η Honda τον θέλει στην McLaren.Αυτή θα βάλει βαθιά το χέρι στην τσέπη. Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
grigor1s 1.558 Αναφορά μηνύματος Δημοσιεύτηκε Σεπτέμβριος 27 , 2014 On-Board από Σιγκαπούρη. http://vimeo.com/107310320 1 Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
grigor1s 1.558 Αναφορά μηνύματος Δημοσιεύτηκε Οκτώβριος 1 , 2014 (τροποποιήθηκε) Honda reveal first picture of 2015 power unit Η πρώτη εικόνα του κινητήρα F1 της Honda για το 2015 Η Honda έχει δώσει στη δημοσιότητα την πρώτη εικόνα της υπερτροφοδοτούμενης μονάδας της για το 2015 πριν από το Ιαπωνικό Grand Prix αυτό το Σαββατοκύριακο. Η Honda θα επιστρέψει στην F1 ως προμηθευτής μονάδων για τη McLaren την επόμενη χρονιά και αυτό το Σαββατοκύριακο στην Suzuka θα δείξει βίντεο και ήχο του νέου V6 turbo της για πρώτη φορά. Η McLaren έχει δηλώσει ότι μπορεί να τρέξει με κινητήρες Honda στις τελευταίες δοκιμές μετά το τέλος της σεζόν, αλλά η ημερομηνία δεν έχει οριστεί ακόμα. «Εργαζόμαστε προς την συμμετοχή της Honda F1 που ξεκινάει από τη σεζόν του 2015, η ανάπτυξη της μονάδας τροφοδοσίας εισέρχεται στη πρωταρχική φάση του στο τμήμα R & D μας στη Sakura (Tochigi, Ιαπωνία), όπου μεταφέραμε το τμήμα ανάπτυξης μηχανοκίνητου αθλητισμού, νωρίτερα αυτό το έτος,» είπε ο Yasuhisa Arai, Ανώτερος Διευθύνων Σύμβουλος της Honda R & D. «Εκτός από τη διεξαγωγή προσομοιώσεων, έχουμε προχωρήσει στο επόμενο στάδιο, όπου θα διεξάγουμε πλήρεις εξετάσεις του κινητήρα σε πάγκο, ενώ συνδέουμε τα συστήματα ανάκτησης ενέργειας και τον υπερσυμπιεστή. «Εν τω μεταξύ, το αγωνιστικά τμήμα μας στο Milton Keynes, στο Ηνωμένο Βασίλειο, έχει γίνει πλήρως λειτουργικό. Αυτή τη στιγμή, έχουμε παρουσιάσει μια εικόνα της μονάδας μας που είναι υπό ανάπτυξη. Όλη η ομάδα επικεντρώνεται στην εξέλιξη αυτής, ετοιμαζόμενοι για την επικείμενη έναρξη της συμμετοχής μας στην F1 σε 6 μήνες. Παρακαλώ μείνετε συντονισμένοι για περισσότερες ενημερώσεις.» Τροποποιήθηκε Οκτώβριος 1 , 2014 από τον grigor1s 2 Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
grigor1s 1.558 Αναφορά μηνύματος Δημοσιεύτηκε Οκτώβριος 2 , 2014 Japanese Grand Prix: Typhoon a threat to race Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
Gen.Markus 6.229 Αναφορά μηνύματος Δημοσιεύτηκε Οκτώβριος 2 , 2014 #LCDM "Life is full of surprises and one must be able to cope with changes, we are proud to close an important cycle.""He (#Alonso) gave everything and did extraordinary performances, We all thought and hoped we have achieved better results" Ο Λούκα μας λέει ότι τελείωσε ο Φερνάντο από την Scuderia. Φήμες αναφέρουν ως βασικότερο αντικαταστάτη για το 2015 τον Jules Bianchi της Marussia και τον Sebastian Vettel της RBR. Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
ksino1100 13.310 Αναφορά μηνύματος Δημοσιεύτηκε Οκτώβριος 2 , 2014 Και τα «πέτρινα χρόνια» για την Ferrari θα συνεχιστούν για πολύ ακόμη....... Ντροπή.... Αν δεν μπορούν να κρατήσουν τον καλύτερο πιλότο της F1, δεν μπορούν να φτιάξουν καλό μονοθέσιο, δεν μπορούν να μη τρώγονται σαν τα κοκόρια, τι θέλουν και συνεχίζουν? Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
Παναγιώτης Κ. 10.057 Αναφορά μηνύματος Δημοσιεύτηκε Οκτώβριος 2 , 2014 Και τα «πέτρινα χρόνια» για την Ferrari θα συνεχιστούν για πολύ ακόμη....... Ντροπή.... Η καλή η μέρα από το πρωί φάνηκε. Πολύ F14T ρε πστ μου.......... Από προχθές το γυροφέρνουν.................. Πρώτα "ο Ράικονεν αισθάνεται επιτέλους καλά με το αμάξι", την επομένη "ο Μπιανκί είναι έτοιμος αν μείνει ελεύθερη θέση"............ ............. τι θέλουν και συνεχίζουν? Δεν γίνεται να σταματήσουν Γιάννη μου, η μόνη ομάδα που έχει συμμετάσχει σε όλα τα πρωταθλήματα από καταβολής αγώνων, η πλέον πολυνίκης (ακόμα), κλπ κλπ. Και μόνο να το εκφράσουν σαν σκέψη, οι τιφόζι θα τους φάνε ζωντανούς, όλους τους. Αφού δεν μπόρεσε να τους κάνει πρωταθλητές ο Αλόνζο, δεν βλέπω χαΐρι........ Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
icelover 2.484 Αναφορά μηνύματος Δημοσιεύτηκε Οκτώβριος 2 , 2014 Kαλώς να έρθει στην Mc Laren.......να ολοκληρωθεί η καύλα.... Ε ναι ρε γαμώτο.......Mc Laren Honda έτσι έχει βιδωθεί στο μυαλό μας.... 1 Μοιράσου αυτό το μήνυμα Σύνδεσμος στο μήνυμα Μοιράσου σε άλλες ιστοσελίδες
