ALX™
ABS Brakes - How Good Are They?
Sunday, January 20, 2008
This is an extract from an ABS test published by MOTORRAD edition 19/2006.
Tested motorcycles:
BMW R 1200 R (with the new Continental-Tewes ABS)
BMW K 1200 S (FTE ABS)
KTM990 ABS (Bosch-Brembo ABS)
BMW F 800 S (Bosch ABS)
Honda CBF 1000 (Nissin-Honda ABS)
Honda Varadero 1000 (Nissin-Honda ABS)
Ducati ST3 a (Bosch-Brembo ABS)
Triumph Sprint ST (Nissin ABS)
Suzuki V- Strom 650 (Nissin ABS, similar to a Bosch system)
Kawasaki ZZR 1400 (Nissin ABS, similar to a Bosch system)
Yamaha FJR 1300 A (Nissin ABS, similar to an early Bosch system)
Stopping performance is measured from 100 - 0 kph, as an average of three runs.
Dry Stretch - equals a normal road
11,7 meter - these are worlds in between the BMW R 1200 R and the Yamaha FJR. Here we have to say that even the FJR in actual practice still functions safer and realizes shorter braking distances than the average rider.
Bad Stretch - includes bumps, edges and potholes of randomly different dimensions
Again the R 1200 R leading an the FJR trailing. But in between them the test field is changing positions. Here the KTM benefits from its longer suspension travel, which filter peak impacts out before it reaches the ABS sensors. The oposite is demonstrated by the Kawasaki. It develops too much slip at the front wheel. The BMW R ABS regulates well with only minor impact on braking performance. 42.6 m means earlier stand still than others on the smooth stretch.
Wet Stretch - evenly water treated with the help of a sprinkler system
With 9,43 m/s the BMW K 1200 S reaches phenomenal braking power in the wet. A contribution of the long wheel base, which keeps the front stabil. The DL650 demonstrates the importance using the rear brake even with ABS. The brake distance was 10 m longer without the rear brake.
'Friction Jump' - a stretch of alternating wet and dry segments, each 20 cm wide
This is the acid test for the ABS's regulating quality. Brake distance of more than 50 m delivered even by the top performers do speak a clear language. The BMW F 800 S ABS regulates harshly but effective. The Kawasaki ABS is careful and therefore too defensive.
CONCLUSION
Never again without! The is the short version and actually all we needed to say, after our experiences with 11 ABS motorcycles. And here is why: What even a very skilled rider can do only occasionally under best conditions, and sometimes only with a lot of luck, that is what the newer ABS systems can do any time - safe braking in the shortest possible distance! The art is to master the effectiveness of the regulating logic in conjunction with the comfortable and clear operation for the rider. It is BMW who gets both under one roof with their new ABS generation. Honda is second with only average braking results, but these systems are top in terms of regulation sensitivity.
Posted by Brian Petterson
Posted by Brian Patterson
Ρε Psychod...τι μηχανάκι πας να πουλήσεις? Αυτά που σκέφτεσαι (και σου προτείνουν να πάρεις) φρενάρουν μια αιωνιότητα αργότερα απ αυτό :pray:
Τρομερή εντύπωση μου κάνει το R1200R που σε καθαρό στεγνό δρόμο φρενάρει με μέσο όρο παραπάνω από 1g!
Επίσης αρνητική εντύπωση προκαλούν και οι επιδόσεις του FJR1300 που φρενάρει όπως ένα φτηνό αμαξάκι πόλης... :o
Κρατώ επιφυλάξεις για την αξιοπιστια των δεδομενων αυτων.Ολα αυτα γιναν σε ιδανικες συνθηκες ή απλα βγηκαν στο δρομο και ειπαν να δοκιμασουν τις επιδοσεις σε καθε μοντελο?
Στη πρωτη περιπτωση τα δεδομενα ειανι αξιοπιστα και προσεγκιστικα για την πραγματικοτητα.στη δευτερη περιπτωση απλα δε θελω καν να τ ακοιταξω...
Τροποποιήθηκε από τον Dare-Devil
Ακόμα και για τις επιδόσεις του fjr λέει πως είναι ανώτερες οποιουδήποτε συστήματος φρένων χωρίς ABS.
Αυτο, για οσους δεν εχουν πειστει ακομα για την χρησιμοτητα του!.. ;) :_thumbsup:
Πολύ ενδιαφέρον τεστάκι ...
Το Motorrad είναι σίγουρα γερμανικό οπότε ίσως να ευνοούν λιγάκι τα δικά τους μηχανάκια ...
Άλεξ, έχεις δίκιο για τον προβληματισμό σου ... κι εγώ το σκέφτομαι - το φρενάρισμα είναι καθοριστικότατο.
Αρχίζω επίσης να αμφιβάλλω για το BUSA χωρίς ABS κατά πόσο είναι καλή αγορά για μένα (που δεν είμαι και "χεράς" στα φρένα). Σίγουρα τα φρένα του Κ είναι "άγκυρες" ΚΑΙ αξιόπιστες μάλιστα!
Οι διαφορές είναι > 10 μέτρα ... μιλάμε δηλαδή ότι με το FJR χτυπάς το σταματημένο τουτού με καμιά 30αρία χλμ/ώρα?!
Τι να πω ... έχω μπερδευτεί ...
Μου δημιουργηθηκε η απορια μηπως οι διαφορες οφειλονται στο βαρος των μηχανων.
Στο ακολουθο πινακακι περιεχονται: το βαρος της μηχανης με επιβατη (βαρος κενη +100), η σχετικη διαφορα κιλων απο την fjr και οι αναλογουντες νεες επιβραδυνσεις στα τρια πρωτα τεστ.
Τα νουμερα ερχονται πιο κοντα με εξαιρεση τις δυο honda. Ομως τα κιλα τα πηρα απο τα τρεχοντα specs στα site των κατασκευαστων.
------------------kg----Δkg%---1o------2o------3o
R 1200 R----300------21-----8.14----7.1-----7.45
K 1200 S----328------11-----8.67
KTM990------306------19-----7.48
F 800 S------287------27-----6.13
CBF 1000----350------4------7.75
Varadero------357-------2------9.3-----7.68---8.48
Sprint ST------310------17-----7.28
FJR 1300 A---364------0-----7.86-----7.08----7.67
Καπου αλλου βρηκα οτι το 2006 οι μηχανες της honda ηταν ελαφρυτερες οποτε πιθανοτατα να ειναι για τη Varadero π.χ.
Varadero-------335------8.6---8.6----7.17--7.85
Μηπως εχουν ολες λιγο πολυ τα ιδια φρενα και αν ναι γιατι αραγε;
Μήπως έπρεπε να πάρω το fazer με ABS τελικά?
Τόρα του late ε? Μακάρι να μπορούσα να βάλω και ας ήταν ακριβότερο...
Nομιζω πως μπορείς να βάλεις!!
Tα φρένα πρέπει να φτιάχνονται αναλόγως των αναγκών της εκάστοτε μοτοσυκλέτας ώστε να την σταματούν στην καλύτερη δυνατή απόσταση.
Δεν υπάρχει δικαιολογία ότι η μία είναι βαρύτερη γι αυτό σταματάει πιο αργά! Ας έβαζες καλύτερα φρένα τότε!!! (Τι είπες?...τα καλύτερα φρένα έχουν μεγαλύτερο κόστος?...ααααα εντάξει βρε...γιατί δεν μας το είπες από την αρχή!!! :whistling: )
Προς mathosala και Psychod
Όσο και να ευνοεί τα δικά τους μηχανάκια κάποιο περιοδικό, δεν γίνεται να δίνει 12 μέτρα πιο αργό φρενάρισμα στο FJR από το R1200R αν το FJR είχε καλύτερα φρένα από το BMW!!! Θα τους έπαιρναν με τις λεμονόκουπες ! Άντε να κλέψουν κάνα μέτρο στο πλαίσιο της εύνοιας, αλλά 12?????
Να σου θυμισω οτι για 30 αργύρια σταυρωσανε τον Χριστό...λες να κολοσουνε για περισσοτερα;... :rolleyes:
ela na imaste dikeoi gia to r1200r ke edw egw ehw diavasi sto superbike oti ehi gamw ta frena
mihanara ine ke to perimena alla afto pou me exeplixe ine i apousia twn ss apo tis prwtes thesis kanonika den tha eprepe na ine afta prwta? as poume tha perimena to varadero na ine patos ke logo varous alla ke logo oti ine pio touristiki mihani
Απ ότι είδες, δεν υπάρχουν SS κατασκευές στο τεστ. Υπάρχουν μόνο street on off και sport touring. Παρόλα αυτά, υπερμηχανήματα που έπρεπε να έχουν φρένα άγκυρες, δεν τα έχουν...δυστυχώς.
Άρα καλό είναι όταν σκοτωνόμαστε για το ποια είναι πιο γρήγορη μοτοσυκλέτα για να αγοράσουμε, καλό θα είναι να κοιτάμε κι αν μπορεί να φρενάρει από αυτά τα χιλιόμετρα που πιάνει, γιατί αλλιώς.....................
Ξέρετε τι είναι 12 μέτρα απόσταση φρεναρίσματος? Αιώνας ολόκληρος όταν μπροστά σου έχει βγει το ΙΧ κάθετα στον δρόμο και σύ πρέπει να φρενάρεις!!!!
Δες και μια παλια (2005) μετρηση, και βγαλε συμπερασματα, γι'αυτο που λες..
Ουδεμια αντιρρηση (εκτος αν δεν γινονται καλυτερα φρενα, που δεν πιστευω οτι ειναι η περιπτωση).
Απλα μια παρατηρηση, αν οντως οφειλεται στο βαρος τοτε στην περιπτωση που τιγκαρουμε τη μηχανη στα μπαγκαζια, οι σχετικες διαφορες βαρους θα πανε κοντα στο μηδεν και οι δυο μηχανες θα φρεναρουν το ιδιο.
Μπορειτε να δειτε (με μια ερευνα στο google) και το "A comparison of stopping distance performance for motorcycles equiped with ABS,CBS and conventional hydraulic brake systems" by Donovan Green , 2006.
Πως να το δουμε ομως αυτο, δεν νομιζω οτι βγαινουν-δημοσιευονται συχνα τετοια αποτελεσματα. Κανω λαθος;
..ΑΥΤΟ! εννοεις??
