StevenGalan
Yamaha Yamaha MT-09 (2014)
2943 μηνύματα σε αυτό το θέμα
Yamaha MT 09 Race Blu HJC RPHA 70 Είναι πολλές
Μάλλον είχες καιρό να το οδηγήσεις και το ξεσυνήθεισες.
Yamaha mt-09 Aprilia tuono v4 aprc (1100cc)
Μπα συνέχεια το οδηγαω.. :blush:
Στα χαρακτηριστικά λέει αύξηση ιπποδύναμης 3%. Κάθε πότε σκοπεύεις να τα αλλάζεις? Ο μηχανικός μου σκίζει τα ρούχα του επιμένοντας για ημισυνθετικό λάδι και συχνές αλλαγές.
300 V 4T Factory Line
10W-40
Racing lubricant for race bikes
100% Synthetic – Double Ester
TYPE OF USE
Race bikes fitted with high performance 4 stroke engines, integrated gearbox or not, wet or dry clutch,
race engines, qualifying engines running at high temperature, over a wide rpm range : speed bikes,
SuperSport, SuperBike, endurance, uphill races, dirt bikes, MX, enduro, trial…
Other uses : street bikes, scooters, ATV, mopeds fitted with catalytic converters.
PERFORMANCE
STANDARDS Above existing standards
Wet clutch compatibility checked on JASO T904 test.
Reference team Alstare World SuperSport, National Moto Endurance, Suzuki World MX
Extra engine power up to 3% : Double Ester technology. Tribologic tests performed put in evidence low
traction coefficient of chosen polymer and complex Esters. Low traction coefficient reduces engine
internal friction and then increase power output.
Engine protection : 0% shear loss on Bosch test ASTM D6278
Gearbox protection : shear resistance improved by 66% on KRL 20 hours tests (CEC L-45-A-99) – test
originally set up for gearbox lubricants, 10 times more severe than Bosch test.
Extra power at the rear wheel : Wet clutch lock up improvement.
Better rev raising, better engine response, maximum engine power.
RECOMMENDATIONS
Oil change: According to your own use.
Can be mixed with synthetic or mineral lubricants.
PROPERTIES
Colour Visual Yellow / Green Fluo
Viscosity grade SAE J 300 10W-40
Density at 20°C (68°F) ASTM D1298 0.860
Viscosity at 40°C (104°F) ASTM D445 82.3 mm²/s
Viscosity at 100°C (212°F) ASTM D445 13.13 mm²/s
Viscosity index ASTM D2270 160
Pour point ASTM D97 -42°C / - 43°F
Flash point ASTM D92 240°C / 464°F
TBN ASTM D 2896 8.3 mg KOH/g
Ducati S2R
Ή γιαμαχα προτείνει 0-40 για  νορμαλ χρήση και 15-50 για σκληρή και πίστα, φουλ συνθετικό.
Suzuki σε νάρκη Shoei αραχνιασμένο εκπτούται
σύμφωνα με τα όσα διάβαζα παλιά σε τουρμποαμαξάδες, τo 300V είναι εκ των πιο-συνθετικό-πεθαίνεις λάδι (και όχι "συνθετικόν") αλλά έχει ως μειονέκτημα τη μικρή διάρκεια ζωής και ως προς την οξείδωση και ως προς την αντοχή στην γραναζοσύνθλιψη
θα δεις στην πορεία του χρόνου, και βλέποντας γράφε εδώ τι βλέπεις
Όταν όμως πας στον αντιπρόσωπο για σέρβις, σου βάζει ημισυνθετικό 10-40 yamalube. Μάλλον η εταιρεία πρέπει να πει και στις αντιπροσωπείες της αυτά που προτείνει. Προσωπικά δεν μου κάθεται καθόλου καλά σε μηχανή που ανεβάζει χαλαρά 11.000 rpm ημισυνθετικά λάδια και για 5.000 χλμ.
Μια χαρά είναι τα ημί.
Και τα 5Κχλμ λιγα είναι. Ανεβαίνεις χαλαρα στα 6Κχλμ με ημί.
Triumph Street Triple R (675cc) Shoei NXR
Δηλαδη τα ημι εχουν σημαντικα μικροτερη διαρκεια ζωης απ τα φουλ?Τα αλλαζω ετσι και αλλιως καθε 5-6Κ απλα ρωταω.
το αντίθετο..
αναλόγως χρήσης-φόρτου-περιβαλλοντικών συνθηκών
Yamaha MT-09 TRACER Shoei NXR Black Ant
εγω δοκιμασα για πρωτη φορα τα αμερικανικα spectro full synthetic 10-40. αλλαγες κανω παντα ανα 5000 με αλλαγη και φιλτρου. μεχρι στιγμης εβαζα τα yamalube 10-40 ημισυνθετικα
Yamaha MT-07 (689cc) Shoei NXR
Ρε παιδιά...από εκεί που δεν μου άρεσε καθόλου το 09 τώρα πια έχει αρχίσει να μ'αρέσει περισσότερο και από το 10!
Άβυσσος τα γούστα του ανθρώπου...
Αρέσει σε 3 μέλη
Yamaha Mt-09
Παιδια πουλαω σελα για το μηχανακι μας, απο το street rally.
Αγοραστηκε πριν ενα μηνα απο Yamaha και ειναι φορεμενη απο μονο μια φορα.
Ειναι πιο παχυα, πιο ποιοτικη και πιο ομορφη απο τη δικη μας.
Οποιος ενδιαφερεται ειναι στις αγγελιες.
http://www.mybike.gr/classifieds/accessories-spares/σέλα-street-rally-για-mt-09-r4650/
Επισης δινω και μια σχαρα ψυγειου που δε την τοποθετησα ποτε,  τιμη: 40€
Τροποποιήθηκε από τον frezas
Yamaha MT-09 Ducati Panigale (1199cc)
το αριστερό μου αυτί έπιασε κροτάλισμα στις 3000rpm.
Τροποποιήθηκε από τον punkabbestia
Πόσα χιλιόμετρα έχουν τα λάδια που έχεις μέσα?
Ducati S2R
Ετσι ξεκινάει...
5k είναι τα λάδια μέσα. λίγο πριν τα 20 συνολικα. για την ώρα δεν καθαρίζω το αριστερό αυτί μέχρι να μην το ακούω...
(οτ)αν το ξανακάνει μετά το σερβις των 20k βλέπουμε
Yamaha MT-09 HJC Rpha 10+ Yamaha
Αγορια ομορφα εχει βαλει κανεις βαλιτσες? ή εστω να το εχει ψαξει?
Δεν μπορω να βρω που βιδωνουν οι βασεις
Ducati S2R
Στο tracer βιδώνουν οι βάσεις, στο δικό μας πρέπει να πάρεις τρυπάνι να αρχίσεις τις τρύπες.:laugh:
Στα πλαστικα ΄ή και στο υποπλαισιο?:cry:
Yamaha Mt-09
Παίδες πουλάω τη μηχανή.
Αν κάποιος ενδιαφέρεται είναι στις αγγελίες.
http://www.mybike.gr/classifieds/motorcycles/πωλείται-yamaha-mt-09-abs-akrapovic-r4715/
http://www.car.gr/classifieds/bikes/view/8521728/
ελπίζω επιλογή και όχι ανάγκη
Αξιζει μια ακτινικη τρομπα?
Στα 200+ για μια καινουρια πχ http://www.car.gr/parts/view/3326227/
Aprilia TUONO V4R ABS (999cc) καποτε...
αν παρεις ακτινικη μην παρεις κατι τετοιο, πας στην brembo rcs 19 με λιγα παραπανω λεφτα και καθαρισες. οσοι την εχουν βαλει δεν τα εκλαψαν τα λεφτα τους
βουαλα μεσιε
Τροποποιήθηκε από τον Gee
Και τι αλλο χρειαζεται? Πχ αλλαγη υγρων? ή μονο εξαερωση?
Σε μεταχειρισμενη τι προσεχουμε?
Τι ρωταω? θα σε παρω να βρουμε μαζι χαχα :laugh:
